Dexcom G6 Receiver Battery Replacement
crwdns2944105:0crwdne2944105:0
Unscrew the 6 Torx T5 screws from the back of the device
Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
Screen Information: Model AM0310R-04 Lot # NHT18080052
Thank you! Where can we buy the screen?
I didn't get any of the details on the screen when I tore it down, I will try to get the information from the original display when I can.
Andrew S -
Have you found any info on getting a replacement Screen? Some company must make theses
Yes, this would be great to know. I can't afford to replace this a 4th for my Daughter, but I while heartedly believe in right to repair!!
I'm not sure if you can find the displays anywhere. The only number (presumably model number) I could find on the screen was AM0310R-04 and the Lot Number NHT18080052.
Andrew S -
Using a spudger, unplug the Charging Port connector from the motherboard.
Remove the 2 silver Torx T5 screws holding the charging port down.
Remove the Charging Port Assembly from the motherboard.
Remove the silver Torx T5 screw holding the motherboard down.
Using a spudger, carefully remove the battery connector on the left side of the motherboard.
Using a spudger, carefully pry up the motherboard to remove it.
Use heat to soften the adhesive holding the battery down.
Carefully use one or more opening picks to remove the adhesive holding the battery down, then remove the battery.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:010crwdne2947412:0
Where do you get battery? Dexcom won't sell it.
I'm not sure you can get this same battery somewhere else (I haven't performed a battery change myself, just took it apart for demonstration). I'll get back to you if I can figure out a way to use another battery.
Andrew S -
@richy14330 The connector type is JST ACHR-03V.
Still looking ... Where to get a battery for this receiver? What type of battery is it ?
I don't think you can get a replacement battery for this device anywhere. It is a 950 mAh 06220 battery made by Jhih Hong Technology. The model number seems to be BAT000023 and the type is 1ICP4/44/59.
Andrew S -
My receiver doesn’t have screws to even open it up to even find a battery. ??
Does yours have the MFG PN # MT24078?
Andrew S -
Where can I get help to replace battery, as I am not computer savvy. I live in Maryland and I need someone to perform this replacement for ne. Pls. Help.
Where can I get help to replace battery, as I am not computer savvy. I live in Maryland and I need someone to perform this.
Andrew S -
