Dexcom G6 Receiver Battery Replacement
  1. Dexcom G6 Receiver Battery Replacement, Display and Front Bezel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dexcom G6 Receiver Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
  3. Dexcom G6 Receiver Battery Replacement, Charging Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Charging Port Assembly from the motherboard.
  6. Dexcom G6 Receiver Battery Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silver Torx T5 screw holding the motherboard down.
  7. Dexcom G6 Receiver Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dexcom G6 Receiver Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
  8. Dexcom G6 Receiver Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, carefully pry up the motherboard to remove it.
  9. Dexcom G6 Receiver Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dexcom G6 Receiver Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dexcom G6 Receiver Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use heat to soften the adhesive holding the battery down.
    • Carefully use one or more opening picks to remove the adhesive holding the battery down, then remove the battery.
Andrew S
crwdns2935283:007/30/21crwdne2935283:0
15 463 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
Where do you get battery? Dexcom won't sell it.
Richy - crwdns2934203:0crwdne2934203:0
I'm not sure you can get this same battery somewhere else (I haven't performed a battery change myself, just took it apart for demonstration). I'll get back to you if I can figure out a way to use another battery.
Andrew S -
@richy14330 The connector type is JST ACHR-03V.
Andrew S - crwdns2934203:0crwdne2934203:0
Still looking ... Where to get a battery for this receiver? What type of battery is it ?
Julian Payne (Xfactor) - crwdns2934203:0crwdne2934203:0
I don't think you can get a replacement battery for this device anywhere. It is a 950 mAh 06220 battery made by Jhih Hong Technology. The model number seems to be BAT000023 and the type is 1ICP4/44/59.
Andrew S -
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 96
crwdns2942667:0crwdne2942667:0 4,536
