Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement
  1. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Remove the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Remove the battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Remove the battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin the repair, remove the battery from the device.
  2. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Loosen the outer housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws securing the outer housing:
    • Twelve T10 screws
    • One 2.5 mm hex screw
    • Some of these screws are deeply recessed. You can use a flathead screwdriver to loosen these screws.
  3. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Remove the right housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Remove the right housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the right housing from the device.
  4. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Loosen the internal parts: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Loosen the internal parts: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lock button from its recess.
    • During reassembly, make sure that the button is properly seated and engages the trigger.
  5. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery connector out of its recess.
  6. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the switch board, switch, and spring from its housing recess.
    • During reassembly, use the third photo as a reference to help you set the components back in the housing.
  7. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Remove the left housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Remove the left housing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Remove the left housing: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully flip the device over.
    • Remove the left housing from the device.
  8. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The spring under the release button has a tendency to fly out. Be careful not to lose the spring.
    • Carefully remove the release button from the device.
    • Remove the button spring from the device.
  9. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Remove the back support: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Remove the back support: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T20 driver to remove the two screws (one on either side) securing the back support .
  10. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the two solenoid wires from the back support.
  11. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the back support straight out of the device.
  12. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Dewalt Nailers DCN680D1 2018 Solenoid Removal: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Dewalt Nailers DCN680D1 2018 Solenoid Removal: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the dowel pin securing the PTO assembly out of the device.
  13. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Loosen the solenoid assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Loosen the solenoid assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T10 driver to remove the two screws securing the solenoid.
  14. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the solenoid away from the device.
    • The solenoid is still connected to the device by two wires. Be careful not to strain the wires.
  15. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the solenoid off the PTO assembly's rails.
  16. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Reassembly tip: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Reassembly tip: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reassembly tip: When you slide the solenoid back onto the PTO assembly, make sure to align the plastic pin to the notch.
  17. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Transfer the minor components: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Transfer the minor components: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement, Transfer the minor components: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver to pry off the rubber stopper securing the plunger pin.
    • Retain the rubber stopper and washer for your replacement assembly.
  18. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plunger pin from the PTO assembly.
  19. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plunger and spring from the PTO assembly.
    • Install the plunger, spring, and pin onto your replacement assembly.
  20. Dewalt Nailers DCN680D1 2018 PTO Assembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the PTO assembly remains.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297 638 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 614crwdne2935297:0
crwdns2942667:0crwdne2942667:0 375
