Dewalt Nailers DCN680D1 2018 Control Module Replacement
  1. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin the repair, remove the battery from the device.
  2. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Loosen the outer housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws securing the outer housing:
    • Twelve T10 screws
    • One 2.5 mm hex screw
    • Some of these screws are deeply recessed. You can use a flathead screwdriver to loosen these screws.
  3. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the right housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the right housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the right housing from the device.
  4. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Loosen the internal parts: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Loosen the internal parts: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lock button from its recess.
    • During reassembly, make sure that the button is properly seated and engages the trigger.
  5. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery connector out of its recess.
  6. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the switch board, switch, and spring from its housing recess.
    • During reassembly, use the third photo as a reference to help you set the components back in the housing.
  7. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the left housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the left housing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the left housing: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully flip the device over.
    • Remove the left housing from the device.
  8. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The spring under the release button has a tendency to fly out. Be careful not to lose the spring.
    • Carefully remove the release button from the device.
    • Remove the button spring from the device.
  9. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the back support: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the back support: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T20 driver to remove the two screws (one on either side) securing the back support .
  10. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the two solenoid wires from the back support.
  11. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the back support straight out of the device.
  12. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Disconnect the control module: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Disconnect the control module: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T10 driver to remove the three screws securing the motor wires
    • Reassembly tip: The motor wires are color-coded. Be sure to reconnect the motor wires as shown in the photo.
  13. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a small flathead screwdriver to pry up and disconnect the sensor connector from the side of the motor.
  14. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of a pick tool into the push-in connector's inlet hole, which has the control module wire plugged into it.
    • Make sure you choose the inlet that connects to the control module, not the solenoid.
  15. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the pick tool still inserted, pull the red control module wire out of the push-in connector.
  16. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the previous two steps to disconnect the black control module wire from the push-in connector.
  17. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip the solenoid's red and black wires from the control module's side.
  18. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the control module: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the control module: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Remove the control module: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove the control module from the device.
    • Reassembly tip: Make sure that the white plastic actuator latches into the black lever arm.
  19. Dewalt Nailers DCN680D1 2018 Control Module Replacement, Transfer the loose components: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Transfer the loose components: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN680D1 2018 Control Module Replacement, Transfer the loose components: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the white plastic actuator from the control module and transfer it onto your replacement part.
    • When you install the actuator, make sure the actuator bar can press the white button on the control module.
  20. Dewalt Nailers DCN680D1 2018 Control Module Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the control module remains.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
299,589 crwdns2915208:0crwdne2915208:0
crwdns2935297:0687crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,116crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,097
