Dewalt Nailers DCN660D1 2018 Driver Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin the repair, remove the battery from the device.
  2. Dewalt Nailers DCN660D1 2018 Driver Removal, Loosen the outer housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 driver to remove the ten screws securing the outer housing.
    • Some of these screws are deeply recessed. You can use a flathead screwdriver to loosen these screws.
  3. Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the right housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the right housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the device on its left side (with the belt hook).
    • Lift and remove the right housing from the device.
  4. Dewalt Nailers DCN660D1 2018 Driver Removal, Loosen the internal parts: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Loosen the internal parts: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lock button from its recess.
    • During reassembly, make sure that the button is properly seated and engages the trigger.
  5. Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery connector out of its recess.
  6. Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the switch board from its housing recess.
    • Remove the two spring clips from the housing.
  7. Dewalt Nailers DCN660D1 2018 Driver Removal, Reassembly tip: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Reassembly tip: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Reassembly tip: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, use these photos to help you align all the loose parts back into the housing.
    • Be sure to route the wires through the yellow groove.
    • Be sure to reattach the spring clips.
  8. Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the left housing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the left housing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the left housing: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully flip the device over.
    • Remove the left housing from the device.
  9. Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The spring under the release button has a tendency to fly out. Be careful not to lose the spring.
    • Carefully remove the release button from the device.
    • Remove the button spring from the device.
  10. Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the back support: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the back support: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T25 driver to remove the two screws (one on either side) securing the back support .
  11. Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the two solenoid wires from the back support.
  12. Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the back support straight out of the device.
  13. Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the driver assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the driver assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal, Remove the driver assembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the driver assembly by its back and pull it straight out of the device.
    • If you are having trouble pulling the driver assembly out, proceed to the next step.
  14. Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailers DCN660D1 2018 Driver Removal: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you have trouble pulling the driver assembly out:
    • Insert a flathead screwdriver into the casing seam above the driver assembly.
    • Slightly pry the housing apart to widen the space for the driver assembly to slide out.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298,023 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,748crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 20
