Dewalt Nailer DCN21PL 2018 Opening Procedure
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove the battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin the repair, remove the battery from the device.
  2. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove casing screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove casing screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T10 driver to remove the four screws securing the bottom half of the casing.
    • Remove the four T10 screws securing the top half of the casing.
  3. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove the magazine: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 driver to remove the screw securing the magazine to the base.
  4. Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the magazine down and away to unlatch and release it from the nailer.
  5. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove framing hook: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove framing hook: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove framing hook: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T15 driver to remove the framing hook retaining screw.
    • Remove the hook.
  6. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove hook clamp: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step may require a lot of force.
    • Use your two thumbs to firmly spread the metal hook clamp apart while slowly pushing it forward off the handle.
    • When this clamp is being removed, it has a tendency to launch off of the handle after you release tension.
  7. Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a sharp blade to slice the label underneath the battery mount to disconnect the two halves of the case.
    • Always cut away from you or others around you.
  8. Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T20 driver to remove the two screws securing the two halves of the case to the front assembly.
  9. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove return system: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove return system: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the provided 3.5 mm hex key to remove the two return system bolts on either side of the nailer.
  10. Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the end cap and slide the return system assembly out of the back of the nailer to remove it.
  11. Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a small flathead screwdriver in the gap between the two halves of the casing near the trigger to pry the two halves apart.
  12. Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a small flathead screwdriver near the top seam to continue prying the case apart .
  13. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove right half of case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove right half of case: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once loose, lift up to remove the right half of the clamshell case.
  14. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove lens cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove lens cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic lens cover.
  15. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove board and switches: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove board and switches: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove board and switches: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The two switches and four detent springs are only held in place by the plastic casing, so they may fall out when you remove the board—this is fine.
    • Grasp either side of the main circuit board and slowly pull it up and out of the slot in the casing.
    • Reassembly tip: note the correct location and orientation of the two switches and their detent springs.
  16. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove trigger lock: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove trigger lock: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up on the trigger lock to remove.
  17. Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove left half of case: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dewalt Nailer DCN21PL 2018 Opening Procedure, Remove left half of case: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the nailer over.
    • Remove the remaining clamshell casing.
Carsten Frauenheim
145.512 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.614crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 46
