This guide will show you how to replace the switch assembly.
Press the battery release button at the top of the battery.
Remove the eight 18 mm Torx Security #10 screws.
Separate the two halves of the outer case. Set the empty side down and out of the way.
Disconnect the connector from the motor assembly.
Pull the motor away from the brush assembly.
Lift the brush assembly out of the drill case.
Pull the armature assembly apart from the brush ring assembly.
Pry the two circled connectors apart from the brush ring assembly.
The brush assembly is now removed from the drill body.
Pull the switch assembly up and out of the drill case.
