The Devialet Gemini, a True Wireless Stereo (TWS) product, can suffer from earwax obstruction of its pipe. It can be noticed by a sound level lowering on one side only (at first), without improvement over time. The high frequencies will be firstly affected, then the medium ones. Perhaps, the earbud affected will produce rattle noises or "dolphin cry" when using ANC (Active Noise Cancellation).
This tutorial results of several dozens of trials of various methods and provides an accessible and robust solution to those who can't activate the warranty anymore.
After performing this, the acoustic performance will only be very slightly affected: around 2dB less punctually around 3kHz (inaudible to most of the listeners) and a very slight stronger (but absolutely acceptable!) sensitivity to ANC instabilities (during ear pull-in or pull-out of the product). Actually, the acoustic mesh removed after this operation seems to be of very small importance in the product design.
Remove the eartip by pulling it.
Insert horizontally a sharp blade, such as a scalpel or a cutter, within one of the large slits and pull out to remove the metallic grid obstructed by earwax. It is attached with an ultrasound welding method, it should come out rather easily.
Remove the acoustic mesh using the same sharp blade. The acoustic mesh is solely attached to the grid with a circular double-sided adhesive. Throw away the mesh: it is generally difficult to clean it, and once cleaned, it is impossible to attach it correctly to the grid without risk for the speaker. Clean the remaining earwax.
Reposition the metal grid on its original location. Press the grid toward the pipe with a flat and rigid tool in order to force the grips to re-integrate the plastic.
This repair should not be done many times on one earbud: while the metal grid will still be solidly attached after one repair, it may not remain firmly after several removal.
If the grid tend to fall, apply a drop of super glue with a toothpick on the periphery of the grid.
crwdns2935229:09crwdne2935229:0
J'ai légèrement endommagé les grilles car j'ai utilisé un cutter standard. Bee recommande plutôt le scalpel
Pensez à bien remettre les grilles en métals dans la même position qu'initialement ! Coup de marqueur avant le démontage par exemple)
Merci pour le tuto
Le faite pas cela a fait que mon écouteur ou j’ai effectué l’opération à cessé de fonctionner
Parfait, j’avais des bruits de dauphins et un niveau sonore extrêmement réduit sur mon écouteur gauche, maintenant j’ai récupéré la stéréo ! Il n’y avait pas tant de cerumen que ça mais la couche était très uniforme et faisait probablement une membrane imperméable. J’ai fait un petit bain d’eau savonneuse et j’ai gratouillé la saleté avec une mini-spatule, c’était très satisfaisant !
Parfait j'étais près a en racheter . Par contre il m’a fallu une loupe . Un grand merci.
Merci pour ce tuto.
Il a l’immense mérite de régler un problème non traité par le fabricant.
Il est indispensable de prendre un bistouri ou un scalpel. Il faut être très méticuleux, une loupe peut être utile.
Avant de commencer, la grille me paraissait propre. Une fois le maillage acoustique, je me suis aperçu d’une fine pellicule de cérumen obstruant la grille de l’intérieur. Le nettoyage de la grille s’est fait avec du dissolvant, une compresse et une aiguille à coudre.
Repositionner la grille m’a paru plus difficile que la retirer.
Quelques tests audio n’ont pas montré de différences à l’écoute, peut-être dues à l’âge ;-)
Encore merci
The method works very well with a few comments: 1. a thin needle is enough to remove the plate, but you have to expect slight bends (it does not affect the sound or the level of protection of the inside, but someday a buyer may complain) 2. the plate is symmetrical, so it does not matter how you put it together later 3. the soft material on the inside is glued by Devialet, but you can remove the glue during cleaning and put it back in without this piece of glue - it will stick 4. when reassembling the plate, you should insert it gently but evenly - you can use a table top for the final press (the side edge is especially convenient because when you hold the receiver in your hand, you can see from above when the plate will go into place) - but not too hard, you will want to clean them again someday :)
