Deutz Brake Cylindern Disassembly
  1. Deutz Brake Cylindern Disassembly, Overveiw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Deutz Brake Cylindern Disassembly, Overveiw: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here is all the parts removed so you have an ide of what is to come.
  2. Deutz Brake Cylindern Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is the cylinders placement on the center housing.
  3. Deutz Brake Cylindern Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First we will remove the adjuster bolt, untighten the nut with 17mm spanner and then unscrew the bolt with a 8mm spanner.
  4. Deutz Brake Cylindern Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next remove the locking ring with lock ring pliers.
    • Flip the cylinder over.
  5. Deutz Brake Cylindern Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove this bigger lock ring taking care since the spring is under some tension.
  6. Deutz Brake Cylindern Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your cylinder is in good condition you might be able to get the piston out with compressed air but mine is rusted in place.
    • So I used a greasegun and some special fittings. A brake pipe fitting threaded for a grease nipple.
    • Replace the air bleed nipple with the greasegun nipple.
  7. Deutz Brake Cylindern Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Plug the hydraulic inlet and use the greasegun to force the parts out.
    • First comes the plunger that in this case was rusted in place.
    • Next the piston.
  8. Deutz Brake Cylindern Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next turn it over and use a 17mm spanner to remove the hand brake arm bolt.
    • Then using a scribe mark the end positions for the arm so you can get it back in the right rotation. Both the arm and the inner pusher have splines so this is a good thing to do.
  9. Deutz Brake Cylindern Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the arm and flip it top side upp.
  10. Deutz Brake Cylindern Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The handbrake axle is locked by a small pin marked with the red arrow. I used a welder and a slidehammer to remove this.
  11. Deutz Brake Cylindern Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next use the slidehammer and a m10 threaded end to remove the habdbrake axle like in picture 2.
  12. Deutz Brake Cylindern Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw that stops the adjuster parts from rotating.
  13. Deutz Brake Cylindern Disassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now we will have to separate these two parts to get the handbrake actuator out.
    • Using a m10 bolt and a metric pipe thread I forced the to rotate in different directions which broke them free,
  14. Deutz Brake Cylindern Disassembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deutz Brake Cylindern Disassembly: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now the top part can be removes followed by the handbrake actuator and lastly the lower part.
Hans
crwdns2935283:004/25/16crwdne2935283:0
430 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 1,027
