Desktop PC RAM Replacement
  1. Desktop PC RAM Replacement, Left Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - crwdns2934203:0crwdne2934203:0
    This is correct.
    DistroHopper39B -
  2. Desktop PC RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Desktop PC RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
  4. Desktop PC RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
crwdns2935229:053crwdne2935229:0
David Lennon
crwdns2935283:004/14/15crwdne2935283:0
10.126 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-5, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 4-5, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S4G5
crwdns2935297:045crwdne2935297:0
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - crwdns2934203:0crwdne2934203:0
how can i differentiate between types of rams
benzy aceware - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 7,668
