Desktop PC Left Panel Replacement
  1. Desktop PC Left Panel Replacement, Left Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - crwdns2934203:0crwdne2934203:0
    This is correct.
    DistroHopper39B -
  2. Desktop PC Left Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Desktop PC Left Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
crwdns2935229:024crwdne2935229:0
David Lennon
crwdns2935283:004/14/15crwdne2935283:0
10,126 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-5, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 4-5, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S4G5
crwdns2935297:045crwdne2935297:0
What is the name of the case used in this tutorial?
Nicolas Hunter - crwdns2934203:0crwdne2934203:0
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - crwdns2934203:0crwdne2934203:0
I have this same case in black and want to know what model it is.
numanair - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 64
crwdns2936753:030crwdne2936753:0 163
crwdns2942667:0crwdne2942667:0 7,303
