Desktop PC Left Panel Replacement
    1. Desktop PC Left Panel Replacement, Left Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    2. Desktop PC Left Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Desktop PC Left Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
crwdns2935229:024crwdne2935229:0
David Lennon
crwdns2935283:004/14/15crwdne2935283:0
10,198 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-5, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 4-5, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S4G5
crwdns2935297:0132crwdne2935297:0
What is the name of the case used in this tutorial?
Nicolas Hunter - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have this same case in black and want to know what model it is.
numanair - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 301
crwdns2942667:0crwdne2942667:0 10,219
