crwdns2959928:0crwdne2959928:0 ↓A computer graphics card allows a computer to plug into a monitor and be displayed. Graphics cards are vital components for computers. Also, replacing a graphics card can help your computer run more quickly and smoothly.
Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
crwdns2935229:086crwdne2935229:0
There should be a notice about the PCI-E slot, which has a security latch; the latch should be pressed in order to remove the graphics card from the motherboard.
Ons NA - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have a all in one pc so this is not relevant
Robert Campanelli - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
any diffrerences in slots?
benzy aceware - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
