crwdns2959928:0crwdne2959928:0 ↓Internal fans keep a computer at a stable temperature while operating. A faulty fan can cause a computer to overheat. It is important that all fans are in working order. Replacing a fan is an important skill for desktop PC users.
Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
Push to unlatch three grey connectors on the front panel.
Disconnect the front panel from the computer face.
Remove four Phillips #2 head, 5mm screws holding in the fan.
Slide the fan out from the side of the casing.
Disconnect the power cable from the fan.
crwdns2935229:039crwdne2935229:0
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I did this with my pc and I was able to restore and add a new fan because the other one wouldn’t work because the wire was snapped so I decided to replace it and this guide helped me
TechNinja - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
