These videos helped me during the four disassembly that I made for various reason and I advice to watch them as well as the written guide that I wrote based on my experience.
Before proceeding to the disassembly remove the coffee filter(marked in green) and the steam knob( marked in light blue): pulling up with a (lot) of force and confidence.
Unplug the machine from the outlet and moving it on a surface with different towels laying on it: the water inside the tubes will be lost during the disassembly.
[back view] Once you remove the clear water tank, you can unscrew the two bottom screws (marked in green) and the two upper screws(marked in red) that will allow us to remove the metallic upper lid later on.
[bottom view] unscrew the 4 hexagonal screaws (marked in light blue) and the two Philips head screws (marked in green) at the base.
Once you removed the black bottom part, you can now remove the plastic tube that brings water from the tank to the heating element. Pull the tubes with strength and confidence (marked in blue)
Once you removed the bottom part, you can start to remove the lid. From the bottom unscrew 3 screw (marked in green)
Remove the water metallic filter for the water (marked in orange)
Remove the valve that allow the water to pass from the internal tank, with a flat head screwdriver (marked in yellow) - you can do this step also without removing the bottom part if you need to replace that single part
Partially remove the lid and remove the yellow/green cable (ground) from the lid (marked in green) pulling it away
Unscrew the screw (marked in purple) to remove the keypad module ( on/off switch, coffee switch, steam switch)
Remove the metallic clip (marked in yellow) to free the rigid tube that bring the water from the external tank to the heating element
Loosen up the metallic clips (marked in blue) that hold the soft tube that link the heating element ( bottom) to the steam exit hole (right). Slide the clips along side the soft tube and remove the tube
Remove the Philips screws(marked in red - Philips) that hold the heating element on the structure
Once you remove the heating element its possible to remove the 4 hexagonal screws on the 4 corner of the element (marked in purple - Allen) This step is useful to remove limescale accumulated in the heating element
Was für einen Schrsubenxieher brauch ich ? Ich bekomme die Schreiben nicht auf
Once you removed the heating element you can replace the necessary pieces : bottom piece(red arrow), O-ring (orange arrow), upper piece (yellow arrow)
We’ll written. I got as far as the internals removal before finding this and reassembled. Thanks, will have another go following your excellent procedure.
Vielen Dank für die Beschreibung.
Ich habe eine Frage zum Erhitzer: Ich möchte die Wasserzufuhr und die Dichtung im Erhitzer tauschen. Ich habe alle Schritte befolgt, bekomme den Behälter jedoch nicht geöffnet, um die Teile auszutauschen.
Kann es sein, dass er stark verkalkt ist, oder muss ich noch etwas lösen – obwohl ich eigentlich nichts mehr sehe, was ich noch lösen könnte?
Vielen Dank für die Unterstützung!
Thank you for the instructions.
I have a question about the heater: I want to replace the water supply and the gasket inside the heater. I have followed all the steps, but I can't open the container to replace the parts.
Could it be that it is heavily calcified, or is there something else I need to loosen – even though I don’t see anything left to unscrew?
Thank you for your support!
To assemble back the device, follow the instruction in reverse order
crwdns2935229:011crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2947412:016crwdne2947412:0
Great, clear instructions and easy to follow. I've been looking to into this machine, and tons of scale in the boiler. works fine now! Cheers
Muss man vor dem zerlegen eig den (wenn vorhanden) Boiler oder Erhitzer entleeren, dass kein restwasser entweicht beim auf-den-Kopf-stellen? Wenn ja, wie geht das? Danke schon mal für den obigen, ausführlichen Bericht!
Hi, I think you can empty the boiler (the one depicted in step 6) before disassemblying the coffee machine. Just try to remove the water container (the one on the back of the machine) and try to "make a coffee". The machine should try to empty the residual water in the tubes, but probably some water will remain inside the boiler.
Either way you can open the boiler (step 6) on a sink so that the residual water won't wet your working space.
VooBee -
Guten Tag, wie bekommt man das Ventil aus der Maschine um es auszutauschen? Ich bekomme es einfach nicht hin. Muss dafür der Erhitzer ausgebaut werden?
Hello,
if you are referring to the valve in step 3 - yellow circle - you can remove it with a flat screwdriver but it's not necessary if you don't need to replace that specific valve.
VooBee -
leider greift der torx scglüssel nicht für die Bodenplattenschrauben. Hat jemand einen Tipp???
Hello,
if you are referring to the hexagonal screws in step 2: yes, they are the worst! I had to drill one of those to push it so that it broke the small plastic base on which it stood. Of course you can't do it to all the 4 screws or you will have a non stable base!
VooBee -
Passen Inbusschlüssel?
Do Allen keys fit?
VauWeh -
Hi, vielen Dank für die sehr gute Anleitung. Hat alles so Step by Step funktioniert. Ich habe den Assy Boiler (fully) ausgetauscht. Ich habe nur leider ein Problem und kann den Grund nicht finden: nach dem Zusammenbau läuft das Wasser nicht unten durch das Sieb in die Tasse, sondern das Wasser kommt irgendwo oben heraus. Habe die Maschine schon zweimal auseinander und wieder zusammen gebaut, immer wieder das gleiche Problem. Vielen Dank für einen Tipp, was ich ggf. falsch gemacht habe.
Hi. The only thing I can think of are those metal clips that tighten the water pipes (step 4, blue circle). Did you put them back on? Are they loose?
VooBee -
Thanks so much. It is so clear, I followed the steps and succeeded in doing a good job for my machine, but unfortunately, I did not succeed in getting the wires back in their proper location. Can anybody help? jak.jak45@yahoo.com
Hi, step 4 and 5 shows the right way the electrical wires are connected, but the only electrical wire I removed is the yellow/green one (ground).
Did you remove any other electrical wire?
VooBee -
Hi. I’ve recently used your excellent guide to replace a pump in a De’Longhi Icona machine. I got stuck at step 4 removing the keypad module. On my UK machine (ECOV310.AZ) there are two screws, not one. Otherwise, an excellent guide. Thank you.
Grytr
Welchen Schraubenzieher brauche ich denn ?
Hi, in the descriptions I wrote the type of screws I found: cross (Philips) and hexagonal (Allen).
I don't remember the exact size for each of the screws, but I used only one Philips screwdriver and one Allen key.
VooBee -
Thank you so much for your tutorial. Very well organized and helpful. I was sble to replace the OPV and get my crema back. Belisimo!
