Dell u3014 monitor repair. Power on problem.
  1. Dell u3014 monitor  repair. Power on problem., Removing bezel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell u3014 monitor  repair. Power on problem., Removing bezel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The u3014 monitor opens the same as most other recent Dell monitors.
    • First remove the stand.
    • Remove the bezel. This can be done by hand and a plastic knife. Approaching the screen from behind, peel the bezel with your fingers (photo).
    • The rest follows quite easily, but in the corners you might need to insert a blade or similar to pry open the clips.
    • When removing the bezel, be careful with the control panel (stuck in place with glue, covered with glued-on strip) and power-button (2 screws).
  2. Dell u3014 monitor  repair. Power on problem., Isolating the PCB: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell u3014 monitor  repair. Power on problem., Isolating the PCB: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the connectors. Black cable to backlight (push clip and pull). Two multi-color cables to LCD (push in the sides and pull). Power and control ribbon (pull). USB hub power (push clip and pull). USB ribbon (lift flap and remove).
    • The frame with PCB is held in place just by metal tape.
    • The USB hub is completely loose.
  3. Dell u3014 monitor  repair. Power on problem., Fixing the problem: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Caution: The circuit board contains capacitors (they look like cylinders) that can shock you if they discharge. Be careful not to touch them as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • To solve power on problems, inspect the board. In my case there was a cold solder joint that actually showed a little spark when plugged in (photo Q816). Re-soldering fixed it. Your case might be harder to find and fix.
    • Many repair guides talk about replacing all capacitors rather aimlessly. In this monitor they used Nichico caps which are very reliable. So that is an unlikely fix.
    • Be extremely careful fixing these switching power supplies, even more so in Europe where one has 230V. Discharge capacitors etc.
    • If you liked this guide, contribute your own.
    • If things are unclear, leave a comment.
crwdns2935229:05crwdne2935229:0
Mark
crwdns2935283:009/05/18crwdne2935283:0
465 crwdns2915208:0crwdne2915208:0
what was the problem with this monitor?
Jason - crwdns2934203:0crwdne2934203:0
This one had a power-on problem. I can’t remember if the power led came on at all.
I have now edited the text.
Mark -
crwdns2942667:0crwdne2942667:0 3,905
