crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Dell latitude 3500crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Dell latitude 3500 Teardown, Remove bottom cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell latitude 3500 Teardown, Remove bottom cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 10 screws total
    • The screws don't come the whole way out of the cover, but you will feel when they are loosened enough.
    • A spudger will make quick work of removing the cover, but you may have to open the laptop to find a spot for it to fit.
    • Sometimes the cover can snag when you go to pull it off: a snap may have caught again, or a screw may be hanging on by a thread.
  2. Dell latitude 3500 Teardown, Remove Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 4 screws total
    • Unplug it from the motherboard.
  3. Dell latitude 3500 Teardown, Remove RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully push the metal latches on each side of the module outwards.
  4. Dell latitude 3500 Teardown, Remove M.2 SSD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove M.2 SSD: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove M.2 SSD: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • One screw holds an aluminum plate in place over the SSD to disperse heat.
    • Another screw holds the actual SSD in place.
  5. Dell latitude 3500 Teardown, Remove USB/SD Card Reader: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove USB/SD Card Reader: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove USB/SD Card Reader: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 2 screws
    • Carefully lift the black tab to free the ribbon cable from it's connection to the motherboard.
    • On the underside is where the CMOS battery is located.
  6. Dell latitude 3500 Teardown, Remove CPU Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the small fan header from it's slot on the motherboard
    • 2 screws total holding the fan in place.
  7. Dell latitude 3500 Teardown, Remove VGA Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell latitude 3500 Teardown, Remove VGA Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 2 screws total
    • the cable can be unplugged from the motherboard by carefully pulling up on the connector
  8. Dell latitude 3500 Teardown, Remove Wi-Fi Card: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove Wi-Fi Card: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove Wi-Fi Card: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 1 screw total, holds a small bracket in place over the antennas.
    • Use a tool to carefully lift the antennas upwards from their connections.
  9. Dell latitude 3500 Teardown, Remove Touchpad: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There's a small amount of tape that needs peeled back
    • 7 screws total
    • There's also a small lip on the top edge of the touchpad that will catch if you pull it out at an angle.
  10. Dell latitude 3500 Teardown, Remove CPU Heatsink: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove CPU Heatsink: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove CPU Heatsink: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 7 screws total
    • The screws are numbered to spread the thermal paste the most evenly across each die.
  11. Dell latitude 3500 Teardown, Lift Hinges: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell latitude 3500 Teardown, Lift Hinges: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 2 screws on each side
    • These hinges hold the 2 halves together, so it will slide when you lift them up
  12. Dell latitude 3500 Teardown, Disconnect Remaining Connections: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There should be three connectors still attached to the motherboard.
  13. Dell latitude 3500 Teardown, Remove Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove Motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove Motherboard: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 4 screws total
  14. Dell latitude 3500 Teardown, Remove Screen Cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove Screen Cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell latitude 3500 Teardown, Remove Screen Cover: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Spudge around the edges, even the hinge.
    • Thin(but strong) adhesive is placed around the border of the screen.
    • 4 screws holding screen in place.
Jake
crwdns2935283:003/08/23crwdne2935283:0
1,336 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 2,518
