Before you begin the RAM replacement process, be sure to ground yourself. Grounding yourself prevents short circuiting the device, and/or shocking yourself. An easy way to do so would be to remove one of your shoes.
Push the sliding button near the battery compartment.
Slide the button next to the battery and lift up on the lip of the battery edge.
Remove the two M2x3mm screws from the center panel on the back of computer with a Phillips #0 screwdriver head.
Use a plastic opening tool to pull up and remove the center panel.
Pull the two clips on either side of the memory sticks.
Slide the memory sticks out of their clips.
