Dell XPS M1530 RAM Replacement
    1. Dell XPS M1530 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the computer upside down with the battery facing you.
      • Turn the computer off and disconnect the charging cable from the computer.
      • Failure to unplug the charging cable may result in electric shock.
    2. Dell XPS M1530 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push the switch as far to the right as possible to unlock the battery.
    3. Dell XPS M1530 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS M1530 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the battery using two hands and pull it away from the computer.
    1. Dell XPS M1530 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
      • Four 3.9mm Phillips #1 screws
      • One 5.8mm Phillips #1 screw
    2. Dell XPS M1530 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS M1530 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the highlighted indent, pull up and out to remove the back panel.
      • The indent should provide enough grip to remove the panel with ease.
    3. Dell XPS M1530 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS M1530 RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push out on the first set of metal tabs to release and remove the top RAM chip.
    4. Dell XPS M1530 RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS M1530 RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS M1530 RAM Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push out on the second set of metal tabs to release and remove the lower RAM chip.
Jase Sasaki
crwdns2935283:001/22/15crwdne2935283:0
721 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-4, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 18-4, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S18G4
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 106
crwdns2942667:0crwdne2942667:0 1,404
