In this guide, you'll be able to safely and correctly remove/replace the Microprocessor Thermal-Cooling Assembly (also known as CPU heatsink) on your Dell XPS M140 laptop, if needed. This Step-by-step guide provides detailed imaging of disassembly, cautioning of notable components, and exact notations for accessing the Dell XPS M140 Microprocessor Thermal-Cooling Assembly.
Open the slide lock and pull out the battery.
Unscrew all of the screws on the underside of the computer that hold the cooling module cover in place and remove the cover.
Unscrew the screws holding the metal bracket in place.
Carefully remove the bracket and the module it is attached to.
The inside should look like this after the bracket and module are removed:
