Dell XPS M1330 RAM Replacement
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • NOTICE: If there is a memory module in DIMM 2, remove it prior to removing the memory module from DIMM 1. Failure to do so could result in damage to both memory modules
    • Turn the computer over and loosen the three captive screws and the M2.5 x 5-mm screw. Remove the module cover.
    • Remove the module from the connector.
    • Align the notch in the module edge connector with the tab in the connector slot.
    • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
    • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
    • Replace the module cover.
    • Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
    • Turn on the computer.
Amia Frazier
crwdns2935283:010/10/19crwdne2935283:0
887 crwdns2915208:0crwdne2915208:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
crwdns2942667:0crwdne2942667:0 133
