Dell XPS M1330 Fan Replacement
  1. Dell XPS M1330 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS M1330 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS M1330 Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  5. Dell XPS M1330 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  6. Dell XPS M1330 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  7. Dell XPS M1330 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the fan and its attachments from the bay.
Kai Kapossy
crwdns2935283:003/24/19crwdne2935283:0
676 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S6-G2, Peak Spring 2019 crwdns2935289:0UMass Dartmouth, Team S6-G2, Peak Spring 2019crwdne2935289:0
UMASSD-PEAK-S19S6G2
crwdns2942667:0crwdne2942667:0 489
