Dell XPS 9720 SSD Replacement
  1. Dell XPS 9720 SSD Replacement, Remove back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen 8 T5 screws. They are all the same length.
  2. Dell XPS 9720 SSD Replacement, Loosen back panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry the back panel off of the carbon fiber upper assembly. Slide it into the crack between the carbon-fiber and aluminum housings, and slide the tool around the perimeter of the device to release the plastic clips holding the two together.
    I noticed that it was easier to start opening it from the edges in the front and once you do all three sides no need to do anything in the rear.
    Artan Muzhaqi - crwdns2934203:0crwdne2934203:0
  3. Dell XPS 9720 SSD Replacement, Unplug the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 9720 SSD Replacement, Unplug the battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your finger in the translucent loop, and pull straight away from the motherboard.
  4. Dell XPS 9720 SSD Replacement, Remove SSD retention screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 9720 SSD Replacement, Remove SSD retention screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 PH1 screws which retain the SSD and heat spreader. The innermost screw also retains the battery, you will have to gently lift the plastic battery mounting tab with your fingernail or a pry tool, allowing the copper heat spreader to be slid out from underneath.
    • The SSD is now free to spring up from the slot. Pull it in a straight line in the direction which it points at rest. Gently insert your replacement drive. Reverse the above steps to reassemble.
    My empty SSD spot was on the right side of the battery.
    DO NOT perform this step without fully removing the battery. If you don't you could very easily break the screw holes on the battery as I did.
    Trevor S - crwdns2934203:0crwdne2934203:0
Sebastien Bolle
crwdns2935283:009/12/15crwdne2935283:0
350 crwdns2915208:0crwdne2915208:0
Do NOT follow this guide. This guide doesn't fully remove the battery. Please fully remove the battery before attempting to removing the SSD heat sink. It's five extra screws and very easy. If you don't fully remove the battery, you could very easily break the screw holes on the battery attempting to remove the heatsink.
crwdns2942667:0crwdne2942667:0 1,285
