Dell XPS 7590 RAM Replacement
crwdns2869540:0crwdne2869540:0: 5K
3
12
85
5,016
crwdns2959984:0crwdne2959984:0: 3
crwdns2959974:03crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 10 - 25 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
You have problems with your RAM? Not detected properly or would like to upgrade to higher capacity RAM? Then this guide is for you!
    1. Dell XPS 7590 RAM Replacement, Flip laptop around: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip your device the other way around
      • Don't be confused that this device is black, its a skin
    2. Dell XPS 7590 RAM Replacement, Remove 10 Torx T5: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 7590 RAM Replacement, Remove 10 Torx T5: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 7590 RAM Replacement, Remove 10 Torx T5: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Grab your T5 Torx and identify the 10 torx screws
      • Make sure that this is a T5, to not strip the screws. They can be very difficult to remove
      • Careful there are more screws, do not try to open yet!
    3. Dell XPS 7590 RAM Replacement, Remove Flap Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Open the flap on the back of the laptop
      • There are two screws that need to be removed, please use a Philips 0 screwdriver
    4. Dell XPS 7590 RAM Replacement, Remove Backplate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The backplate might not be easy to open
      • You can use a soft prytool to open the laptop easier
      • Don't insert the tool too deep or you might break the mainboard
      • Now, you should be able to remove the backplate
    5. Dell XPS 7590 RAM Replacement, Unplug Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 7590 RAM Replacement, Unplug Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 7590 RAM Replacement, Unplug Battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the battery connection to the mainboard
      • Unplug the battery before doing anything else
      • You can use a pry tool to make this easier
    6. Dell XPS 7590 RAM Replacement, Locate and remove RAM: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 7590 RAM Replacement, Locate and remove RAM: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the RAM on the mainboard
      • Gently push down on the 2 outside tabs of the RAM stick you want to replace
      • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up
      • Firmly grasp the RAM stick from the flipped up edge and gently pull out, releasing the RAM stick
    7. Dell XPS 7590 RAM Replacement, Insert new RAM: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 7590 RAM Replacement, Insert new RAM: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 7590 RAM Replacement, Insert new RAM: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the new RAM sticks into the socket or reseat the one that is already there if the ram is not detecting properly
      • Make sure to align the RAM properly in the slot before pressing down
      • Then press down to have the RAM to seat in correctly
    8. Dell XPS 7590 RAM Replacement, Plug battery back in and reassemble: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Plug battery back in
      • Place backplate on top again and reassemble
Max Lembke
crwdns2935283:009/14/19crwdne2935283:0
951 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 85
crwdns2959996:0crwdne2959996:0 5,016
