Dell XPS 18 Battery Replacement
  1. Dell XPS 18 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Battery Replacement, Internal Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
    It’s not necessary to remove the cables. Unclip the white touch cable from the touch board as shown in step 8, then remove the two screws holding the board to the frame, as shown in step 9. The board can then be moved out of the way to lay flat on your work surface without having to disconnect all the cables. Doing this eliminates this step and step 5. The order of operations then would be steps 1-3, 8, 9, 6, 7, and 10.
    Strephon Alkhalikoi - crwdns2934203:0crwdne2934203:0
  5. Dell XPS 18 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 18 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 18 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Battery Replacement, Touch Control Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 18 Battery Replacement, Touch Control Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 18 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 18 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  10. Dell XPS 18 Battery Replacement, Wireless WLAN Card Wires: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
    I pulled these up with my fingernails - I have small hands and the tool was too clumsy for me.
    stacysaw - crwdns2934203:0crwdne2934203:0
  11. Dell XPS 18 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 18 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull back the cables.
  12. Dell XPS 18 Battery Replacement, Battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool's angled edge to pry the black battery cable loose.
    This little snap can be tough to lift up. If you get your face right down on the board you can see that it pops upward from the side. Pic looks like it might be from the top.
  13. Dell XPS 18 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool's angled edge to remove the red and black CMOS battery cable.
    I was able to pull this free with my fingernails. Using the tool was too clumsy for such a small piece.
  14. Dell XPS 18 Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 18 Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool's angled edge to lift the clasp securing the silver circuit board cable.
    • Pull back the circuit board cable to prevent future hassle.
  15. Dell XPS 18 Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the opening tool's angled edge to remove the CMOS battery.
    • The CMOS battery is adhered with strong adhesive; you may need to use extra force when removing.
  16. Dell XPS 18 Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eleven black 4mm screws holding the battery in place with a Phillips 00 screwdriver.
  17. Dell XPS 18 Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
    it seems obvious, but after you lift out the battery you're looking a plain white plastic case. That's fine - you can go back through the steps omitting the ones of putting the battery and CMOS battery cables back in place. Basically, just reattach anything that's still there.
crwdns2935229:013crwdne2935229:0
Austin Weir
crwdns2935283:001/31/15crwdne2935283:0
1,287 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-29, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 6-29, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S6G29
crwdns2947412:09crwdne2947412:0
needs the help to repair the Dell XPS18
anrew waleta - crwdns2934203:0crwdne2934203:0
This is an excellent doc! Pictures are really clear and accurate, steps are concise and best of all they are correct. I was able to solve my issue the first go round with these instructions. Kudos to the author and thanks a million for the assistance!
Excellent!
What is the battery type and where to buy, thanks
Mohammad - crwdns2934203:0crwdne2934203:0
My unit is missing the right foot stand. Is there anywhere else I can find the model number. Need to purchase a new power supply?
Also might need to replace the touchscreen its cracked. Have to power her up first to find out. Do you have a video for touchscreen replacement?
Frank Schofield - crwdns2934203:0crwdne2934203:0
I did this and now my comp just has a double blinking white light…? and will not turn on.
matt5331 - crwdns2934203:0crwdne2934203:0
Mine too, did you manage to find what it was?
Alan Jones -
Wow! I cannot believe how straight forward this guide is!!! Photos depicting every step. My computer now says “1 hour and 12 min until full charge"!!!! Thank you very much!!!!!
Robert Brown - crwdns2934203:0crwdne2934203:0
I replaced the battery and still having the same problem. Please help
Chris Nick - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 16,319
