Dell XPS 15 9570 Touchpad Replacement
  1. Dell XPS 15 9570 Touchpad Replacement, Base Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Touchpad Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Touchpad Replacement, Heat Sink: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement, Heat Sink: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
  10. Dell XPS 15 9570 Touchpad Replacement, Fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement, Fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  11. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  12. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  13. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
  14. Dell XPS 15 9570 Touchpad Replacement, RAM: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement, RAM: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
  15. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
  16. Dell XPS 15 9570 Touchpad Replacement, SSD: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement, SSD: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  17. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hands, hold the SSD and slightly pull to the left.
  18. Dell XPS 15 9570 Touchpad Replacement, Wireless Card: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement, Wireless Card: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  19. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the wireless card bracket off of the wireless card.
  20. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  21. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the wireless card.
  22. Dell XPS 15 9570 Touchpad Replacement, Speaker: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement, Speaker: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speakers from the back of the computer.
    • Replace speakers with Dell 6GTPY 91 Wh Battery.
  23. Dell XPS 15 9570 Touchpad Replacement, Touchpad: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement, Touchpad: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two motherboard cables using the opening tool.
  24. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the four 4mm screws securing the hard drive cover.
  25. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two motherboard cables located on the right of the motherboard using the opening tool.
  26. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, unscrew the 4 remaining 4mm screws holding the motherboard in place.
    • Remove the motherboard.
  27. Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9570 Touchpad Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 screwdriver, unscrew the two 2.4mm screws holding the touchpad in place.
    • Remove the touchpad.
Sophie
crwdns2935283:011/09/23crwdne2935283:0
349 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-1, Harley Fall 2023 crwdns2935289:0IUPUI, Team 3-1, Harley Fall 2023crwdne2935289:0
IUPUI-HARLEY-F23S3G1
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 1,131
