Use this guide to learn the steps to remove the keyboard of your Dell XPS 15 9570. The keyboard is an input device used to enter characters and functions into your computer system by pressing the keys.
Prior to starting this guide, be sure the laptop is powered off and it is unplugged from the charging cord.
Flip the device over so the base cover of the computer is facing upwards.
Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
Lift the back cover off of the device.
Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
For laptops with the larger battery, there are actually 9 screws to remove.
My previous comment is incorrect, it is 7 screws, not 9, for the larger battery
in the red circles wrong screws marked.
Is this 9570 model in previous guide you have 91wh and here you showing 56wh battery which is for xps15 9560 I will open myself mine before ordering replacement as your photos presenting model 60' not 70'
Use the iFixit opening tool to disconnect the battery connector from the motherboard.
With your hands, pick up and remove the battery from the system.
Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
Lift the right fan off of the device.
Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
Using your hands, hold the SSD and slightly pull to the left.
Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
Lift the wireless card bracket off of the wireless card.
Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
Disconnect the two motherboard cables using the opening tool.
Using a Phillips #0 screwdriver, remove the four 4mm screws securing the hard drive cover.
Disconnect the two motherboard cables located on the right of the motherboard using the opening tool.
Using a Phillips #0 screwdriver, unscrew the 4 remaining 4mm screws holding the motherboard in place.
Remove the motherboard.
Disconnect the keyboard cables, labeled BL and KB, using the opening tool.
Unscrew the 1.9mm screws using a Phillips #00 screwdriver.
Flip the cutouts on the keyboard to reveal and unscrew remaining 1.9mm screws underneath.
Remove the keyboard.
A #00 is too large. It needs to be a #000 screwdriver.
Thanks alot.
Motherboard: 2 more cables to disconnect.
Keyboard backside some more screws to remove.
Great guide. Same thing for me though: 2 extra very small cables to disconnect from MB. Also had extra screws on LHS to remove for battery. Have to fiddle a bit with ribbon cables (KB and BL) on replacement keyboard as it is designed for several laptop models.
Advice to users: take photos along the way, be very careful and be aware that small variations can exist for a given laptop model.
