Dell XPS 15 9560 Motherboard Replacement
  1. Dell XPS 15 9560 Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Motherboard Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  6. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingernails to gently "walk" the battery connector directly out of its socket.
  7. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  8. Dell XPS 15 9560 Motherboard Replacement, Hard Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  9. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  10. Dell XPS 15 9560 Motherboard Replacement, Solid State Drive (SSD): crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  11. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  12. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
  13. Dell XPS 15 9560 Motherboard Replacement, Wireless Card: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
  14. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the wireless card cables from the wireless card.
  15. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the wireless card out of its slot.
  16. Dell XPS 15 9560 Motherboard Replacement, Fans: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  17. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the fan cable.
  18. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the left-side fan.
  19. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  20. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the right-side fan.
  21. Dell XPS 15 9560 Motherboard Replacement, RAM: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9560 Motherboard Replacement, RAM: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
  22. Dell XPS 15 9560 Motherboard Replacement, Motherboard: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
    • Remove the bracket and unplug and loosen the LCD cable.
  23. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws securing the motherboard to the device.
  24. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From right to left, unplug the bottom motherboard cables, DC jack cable, speaker cable.
  25. Dell XPS 15 9560 Motherboard Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
Jada Houser
crwdns2935283:009/28/21crwdne2935283:0
848 crwdns2915208:0crwdne2915208:0
Clemson, Team 4-5, Hunter Fall 2021 crwdns2935289:0Clemson, Team 4-5, Hunter Fall 2021crwdne2935289:0
CLEM-HUNTER-F21S4G5
crwdns2935297:019crwdne2935297:0
crwdns2942667:0crwdne2942667:0 4,595
