Dell XPS 15 9550 RAM Replacement
  1. Dell XPS 15 9550 RAM Replacement, Back/Underside Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9550 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9550 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9550 RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9550 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 2 separate RAM sticks.
    • Gently push down on the 2 outside tabs of the RAM stick you want to replace.
    • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
  5. Dell XPS 15 9550 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9550 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
crwdns2935229:05crwdne2935229:0
jbaseballin2
crwdns2935283:010/04/18crwdne2935283:0
117 crwdns2915208:0crwdne2915208:0
UW Stout, Team S6-G1, Ogden Fall 2018 crwdns2935289:0UW Stout, Team S6-G1, Ogden Fall 2018crwdne2935289:0
UWSTOUT-OGDEN-F18S6G1
crwdns2935297:023crwdne2935297:0
What type ram do you replace it with? Could you post a link?
twrfan - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,065
