Dell XPS 15 9550 Battery Replacement
  1. Dell XPS 15 9550 Battery Replacement, Back/Underside Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9550 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9550 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9550 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9550 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips #00 Screwdriver to remove the seven 3 mm long screws from the perimeter of the battery.
    • Each screw is labeled "M2X4" with an arrow pointing to the screw.
  5. Dell XPS 15 9550 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up on the backside of the battery.
  6. Dell XPS 15 9550 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9550 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9550 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly grasp the black connector on both sides.
    • Carefully pull the connector towards the battery, to release the connector and the battery from the laptop.
crwdns2935229:055crwdne2935229:0
Brandon Schmidt
crwdns2935283:010/04/18crwdne2935283:0
2,138 crwdns2915208:0crwdne2915208:0
UW Stout, Team S6-G1, Ogden Fall 2018 crwdns2935289:0UW Stout, Team S6-G1, Ogden Fall 2018crwdne2935289:0
UWSTOUT-OGDEN-F18S6G1
crwdns2935297:023crwdne2935297:0
crwdns2947412:013crwdne2947412:0
… Mais avec un prix imbattable, la batterie made in RPC arrive avec un connecteur très très épais !
Finalement il m’a fallu me résigner à forcer très durement l’intromission avec deux paires de pinces !!!
Barbare mais efficace ! C’est le contraire de out ce que j’ai enseigné pendant des années : “le connecteur approprié doit toujours s’insérer en douceur” Ben là … NON !
Jp Chainais - crwdns2934203:0crwdne2934203:0
English translation:
… But with an unbeatable price, the battery made in RPC comes with a very very thick connector!
Finally, I had to resign myself to forcing the intromission very hard with two pairs of pliers !!!
Barbarian but effective! It’s the opposite of what I’ve taught for years: “the right connector should always fit smoothly” Well there… NO!
Richard Persen -
Hallo, ich habe alles nach Anleitung durchgeführt, allerdings kommt eine Fehlermeldung, dass der Akku nicht akzeptiert wird, da kein Original Ersatzteil.
Den Haken im Bios bei Adapter Warnings habe ich bereits entfernt. Hat jemand eine Idee?
Thomas Haupenthal - crwdns2934203:0crwdne2934203:0
Hallo Thomas, wo kommt denn die Fehlermeldung? Im BIOS? In deinem Betriebssystem? In einem bestimmten Programm? Was läuft denn auf deinem Dell?
Fabian Neidhardt -
Geht mir auch so: Fehlermeldung im BIOS auf Windows 10. Ob ein BIOS-Update das Problem lösen würde weiß ich nicht, weil ich dafür 10% Akkuladestand bräuchte.
Fuchs -
crwdns2936753:07crwdne2936753:0 68
crwdns2936753:030crwdne2936753:0 336
crwdns2942667:0crwdne2942667:0 82,073
