Dell XPS 15 9530 Hard Drive Replacement
  1. Dell XPS 15 9530 Hard Drive Replacement, Unscrewing the Base-Cover Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • Don't forget to unscrew the two screws hidden under the system badge!
  2. Dell XPS 15 9530 Hard Drive Replacement, Prying Off the Base-Cover Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
  3. Dell XPS 15 9530 Hard Drive Replacement, Remove Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery off the palm-rest assembly.
    • After you remove the battery, turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
  4. Dell XPS 15 9530 Hard Drive Replacement, Unscrew Hard Drive From the Laptop: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the palm-rest assembly.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
    • Lift the hard-drive assembly off the palm-rest assembly.
  5. Dell XPS 15 9530 Hard Drive Replacement, Remove Hard Drive From Bracket: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the interposer from the hard-drive assembly.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
    • Lift the hard drive off the hard-drive bracket.
To reassemble your device, follow these instructions in reverse order with the replacement hard drive.
Johnathan Hammond
crwdns2935283:002/28/18crwdne2935283:0
45.411 crwdns2915208:0crwdne2915208:0
crwdns2935297:0408crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01.991crwdne2935297:0
crwdns2936753:030crwdne2936753:0 116
crwdns2942667:0crwdne2942667:0 5,781
