Dell XPS 15 9520 Battery Disconnect
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Dell XPS 15 9520 Battery Disconnect, Unfasten the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9520 Battery Disconnect, Unfasten the back cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to remove the eight 3.3 mm-long screws securing the back cover.
  2. Dell XPS 15 9520 Battery Disconnect, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9520 Battery Disconnect, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the bottom-left corner of the aluminum back cover and the chassis.
    • Leave the pick inserted before continuing to the next step.
  3. Dell XPS 15 9520 Battery Disconnect, Release the corner clip: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9520 Battery Disconnect, Release the corner clip: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of the spudger into the gap you just created.
    • Pry up to release the corner clips.
    • Repeat this process for the opposite corner of the back cover.
  4. Dell XPS 15 9520 Battery Disconnect, Unclip the front edge: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9520 Battery Disconnect, Unclip the front edge: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9520 Battery Disconnect, Unclip the front edge: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinsert your opening pick under the aluminum cover at the front edge of the laptop.
    • Pry to loosen the cover.
    • Pry at multiple locations along the front edge to release all of the retaining clips.
    • Do not use a sliding motion along the front edge. This may damage cables near the trackpad.
  5. Dell XPS 15 9520 Battery Disconnect, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9520 Battery Disconnect, Remove the back cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9520 Battery Disconnect, Remove the back cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The edges of the back cover are very sharp. Use caution when handling it.
    • Lift the back cover off the chassis and remove it.
    • If the back cover feels stuck to the chassis, use an opening pick to release any remaining clips around the back cover's perimeter.
  6. Dell XPS 15 9520 Battery Disconnect, Disconnect the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9520 Battery Disconnect, Disconnect the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9520 Battery Disconnect, Disconnect the battery: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
86.430 crwdns2915208:0crwdne2915208:0
crwdns2935297:0455crwdne2935297:0
crwdns2942667:0crwdne2942667:0 40
