Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Wedge the case apart with a nylon spudger.
Slide spudger along each side of the laptop
Lift the back panel of the laptop off and set it aside.
Remove the single screw from the left side of the SSD using a Phillips #00 screwdriver.
Use your fingers to carefully remove the SSD from the laptop.
