Dell XPS 15 9510 SSD Replacement
  1. Dell XPS 15 9510 SSD Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 SSD Replacement, SSD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9510 SSD Replacement, SSD: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single screw from the left side of the SSD using a Phillips #00 screwdriver.
    • The SSD is spring-released; it will pop up after removing the screw.
  5. Dell XPS 15 9510 SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to carefully remove the SSD from the laptop.
Austin Sa
crwdns2935283:003/30/22crwdne2935283:0
432 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-3, Mellen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-3, Mellen Spring 2022crwdne2935289:0
UMASSD-MELLEN-S22S1G3
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 4,842
