Laptop hinge replacement is important because it ensures that the display system stays in place without wobbling, moving, or being too tight. A broken hinge will affect the usability of your laptop. This guide will show you how to replace the hinges using the iFixit iOpener tool.
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Wedge the case apart with a nylon spudger.
Slide spudger along each side of the laptop
Lift the back panel of the laptop off and set it aside.
Using the small battery pull tab, disconnect the battery connector from the motherboard.
Remove eight 2.5 mm from around the perimeter of the battery using a Phillips #0 screwdriver.
Remove the old battery from the laptop.
Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
Remove five screws that connect the display using a Phillips #00 screwdriver.
Carefully remove the display from the Dell XPS 15 9510.
Heat the iOpener in the microwave for 30 seconds.
Place the iOpener on top of the laptop where the hinge is connected. Leave it there until the glue holding it in place melts.
Pull out the hinges using a pair of needle nose pliers.
