Dell XPS 15 9510 Fan Replacement
Bethany Wright
crwdns2944107:0crwdnd2944107:0Bethany Wrightcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0May 7, 2024crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
Failure of fans to turn on automatically can lead to devices overheating. This guide shows how to replace the two fans located within the Dell XPS 15 9510 laptop. Be sure to remove small parts carefully.
Before using this guide, make sure to review the Dell XPS 15 9510 troubleshooting page to review if it isn't a BIOS issue or anything else.
Your fans might also be dirty; you can use these steps to locate your fans before cleaning them using a DataVac. If that is the case, you won't need to replace your fans.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
crwdns2944105:0crwdne2944105:0
  1. Dell XPS 15 9510 Fan Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9510 Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
  5. Dell XPS 15 9510 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9510 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently unplug the motherboard fan connector using a pair of tweezers.
  6. Dell XPS 15 9510 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the motherboard connector on the other fan using a pair of tweezers.
  7. Dell XPS 15 9510 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9510 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently slide and then lift the fans out of their positions.
  8. Dell XPS 15 9510 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9510 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9510 Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step and remove the other fan.
Bethany Wright
crwdns2935283:007/13/23crwdne2935283:0
439 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-1, Harley Summer 2023 crwdns2935289:0IUPUI, Team 2-1, Harley Summer 2023crwdne2935289:0
IUPUI-HARLEY-SU23S2G1
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 1,302
