Dell XPS 15 9500 Battery Replacement
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 15 9500 Battery Replacement, Remove the base cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the eight 3 mm screws that secure the base cover to the palm-rest and keyboard assembly.
  2. Dell XPS 15 9500 Battery Replacement, Remove the base cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting from the bottom-left corner, use a plastic scribe (spudger) to pry the base cover in the direction of the arrows to release the base cover from the palm-rest and keyboard assembly.
    • Grasp the left side and the right side of the base cover and remove the base cover from the palm-rest and keyboard assembly.
    • The edges of the base cover are very sharp. Use caution when handling it.
  3. Dell XPS 15 9500 Battery Replacement, Disconnect battery cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery cable from the system board.
    Disconnecting this cable was particularly difficult for me. I found that this was easiest when I had already removed the battery. The technique that worked for me was pushing on either side in turn to slowly dislodge it, rather than using the notch on top of the connector.
    Miguel Guthridge - crwdns2934203:0crwdne2934203:0
    I skipped this step and connected the replacement battery to the existing cable. Thanks Miguel for getting me started in that direction by removing the battery first.
    Jeff G. - crwdns2934203:0crwdne2934203:0
  4. Dell XPS 15 9500 Battery Replacement, Drain the flea power: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn your computer over and press the power button for 15 seconds to drain the flea power.
  5. Dell XPS 15 9500 Battery Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the four screws (M2x4) that secure the battery to the palm-rest and keyboard assembly.
    • Remove the four screws (M2x3) that secure the battery to the palm-rest and keyboard assembly.
    • Peel the tapes that secure the speaker cable to the battery.
    • Lift the battery off the palm-rest and keyboard assembly.
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
crwdns2935283:004/22/20crwdne2935283:0
40.916 crwdns2915208:0crwdne2915208:0
The Home Depot crwdns2935289:0The Home Depotcrwdne2935289:0
Community
crwdns2931471:018.581crwdne2931471:0
crwdns2935297:0109crwdne2935297:0
crwdns2947412:011crwdne2947412:0
It seems there are issues with replacement Dell batteries causing the touchpad to behave erratically (https://www.dell.com/community/XPS/xps-1...), with impaired action of the left 'mouse button' on the pad, and the left button either clicking randomly or appearing to be held down. Have returned a (so-called) compatible 3rd party battery for my XPS15 9500 and now going to try an original Dell replacement. The problem seems to be battery thickness, i.e. not giving the touchpad room to correctly operate.
Simon Conway-Smith - crwdns2934203:0crwdne2934203:0
It should also be noted that most replacement batteries don't come with the battery connection cable, so you need to remove it from the existing battery and install it on the replacement. The cable seems to come off with a slight pull (once unstuck and the securing tape next to the connector is lifted), and inserts onto the new battery by just pushing it down onto the connector.
Actually I think this may the best way to install the battery. I could easily see damaging the motherboard trying to disconnect the cable from the motherboard.
Jeff G. -
Seconding for the missing battery connection cable; there are no instructions for moving this from the old battery to the new, and it doesn't come with one. Caveat Emptor!
Will Sadkin - crwdns2934203:0crwdne2934203:0
my XPS 15 9500 does not recognize the new battery
Jp221 - crwdns2934203:0crwdne2934203:0
The touchpad doesn't work after installing this battery. I can move the cursor around, but clicking is not possible. So it's better to get an original Dell battery.
Sebastiaan Been - crwdns2934203:0crwdne2934203:0
My XPS 9500 does not recognize the new battery. Not happy
John Hardman - crwdns2934203:0crwdne2934203:0
FWIIW: Dell doesn't ship the batteries with the stupid cable either. You have to order it separately and it isn't clearly available on their website. We had a batter replaced via OEM via Dell via our IT Consultant and they even fell into this trap. Waited another 3 weeks to get the cable from Dell.
The Holocron - crwdns2934203:0crwdne2934203:0
Very disappointed in this fix. To start, I thought I had purchased a genuine Dell replacement battery, but it's clearly aftermarket. I purchase here because I like to purchase genuine parts and support the fixit community in general, but I can find less expensive aftermarket parts elsewhere.
Then the guide was incomplete as others have mentioned, omitting any mention of the bottom battery connector. There was also a missed opportunity to show how to remove and clean the fans and heat pipe fins. By the time you are ready for a replacement battery, you can be fairy certain a basic internal cleaning is in order as well.
I've been a customer for many years, but this was the first time that I was actually unhappy with my experience. Hopefully an anomaly.
Eidolen - crwdns2934203:0crwdne2934203:0
Is there a way to fix the trackpad problem when updating to the new battery?
Bill T - crwdns2934203:0crwdne2934203:0
I did not encounter a trackpad problem before or after replacing mine, but from what I’ve read and experienced - using a battery purchased from Dell should work best. My new battery from Dell worked fine for me.
That said, if I was on a very tight budget I would consider trying one from iFixit - they have good customer service and will replace or refund if it doesn’t work properly.
I’ve seen many laptop batteries begin to swell as they get old, that may be causing a trackpad issue.
Since my battery replacement was on a work laptop, I went with genuine Dell to ensure the best results (and convinced my manager to purchase it).
Daniel Cassel -
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 127
crwdns2936753:030crwdne2936753:0 475
crwdns2942667:0crwdne2942667:0 16,977
