Dell XPS 14 Speaker Replacement
  1. Dell XPS 14 Speaker Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
  2. Dell XPS 14 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 14 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 14 Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
  3. Dell XPS 14 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 14 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
  4. Dell XPS 14 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 14 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 14 Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
  5. Dell XPS 14 Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 14 Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
  6. Dell XPS 14 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 14 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
Gabriella Monico
crwdns2935283:003/23/22crwdne2935283:0
457 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-3, Botvin Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-3, Botvin Spring 2022crwdne2935289:0
UMASSD-BOTVIN-S22S1G3
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 297
