The device featured in this replacement guide is the Dell XPS 14 L421X. This guide will assist the user in removing and replacing the laptop's fan. There are no special skills or requirements for this guide, the user will only need to complete the steps shown. The fan may often be the cause for the device overheating. For more troubleshooting information, refer to the troubleshooting page. Before fully removing the fan, make sure you check to ensure that the fan is connected to the device, as these symptoms may also be due to a loose cable or plug. Before following these steps, it is important that you ground yourself by wearing an anti-static wrist strap. Also, make sure that the battery is fully disconnected before removing the fan.
Position the computer back side up so that the “XPS” logo is facing you.
Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
Use an opening tool to pry up the metal plate.
Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
Use an opening tool to pop out the back panel.
Flip over the back panel so that the interior of the panel is facing up.
Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
Remove the black plastic cover that holds the disk in place.
Remove the back panel.
Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
Remove the speaker from its original location so the wire connector is visible.
Unplug the red and white cable plug by pulling out the white end tag.
The speaker is now fully removed.
Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
Detach the battery connector from the motherboard using two thumbs to pop it out.
Remove the battery from the laptop.
Remove the two 2 mm screws from the fan using a Phillips #0 screwdriver.
Use two thumbs to pop out the plug that connects the fan to the laptop.
Remove the fan from the laptop.
Thanks for sharing! One question: Isn't it sufficient to just remove the plug of the battery?
