Click here for the updated version of this guide. The guide you are currently viewing is archived here for historical purposes only.
Remove the eight 4 mm T5 Torx screws from the bottom cover.
Use a plastic opening tool to pry open the 'XPS' flap in the middle.
Remove the single Phillips screw hidden beneath the flap.
Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
Remove the black, 4 mm Phillips #000 screw on the right of the SSD.
Gently lift the SSD card with your hand to pull it up and to the right.
