Dell XPS 13 L321X Screen Replacement
  1. Dell XPS 13 L321X Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 L321X Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove ten 3mm screws from the back cover with a "T5" screwdriver.
  2. Dell XPS 13 L321X Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbons from both sides with a plastic iFixit opening tool.
  3. Dell XPS 13 L321X Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 L321X Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black wire that connects the screen to the motherboard by pulling up with a plastic iFixit opening tool.
  4. Dell XPS 13 L321X Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 L321X Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and pulling the white ribbon off.
    • Pull aside the ribbon cable.
  5. Dell XPS 13 L321X Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 13 L321X Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 13 L321X Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the wire that is connected to the wireless card with a plastic iFixit opening tool by lifting up slowly, then pulling the wires aside.
  6. Dell XPS 13 L321X Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a PH00 size screwdriver to remove the 8 screws that secure the battery.
    • Six 3mm screws.
    • Two 5mm screws.
  7. Dell XPS 13 L321X Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 L321X Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic iFixit opening tool in between the port and the wires to remove the battery cable.
  8. Dell XPS 13 L321X Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 13 L321X Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 13 L321X Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the battery, start to remove the wireless wire and making it through the other wires connected under the battery.
  9. Dell XPS 13 L321X Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 L321X Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws with a PH1 size screwdriver.
    • Each side of the brackets that are holding the screen down are going to have two 3mm screws in each side.
  10. Dell XPS 13 L321X Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 13 L321X Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 13 L321X Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the laptop by separating the screen from the actual laptop and take it apart.
Molly Skinner
crwdns2935283:002/15/17crwdne2935283:0
270 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S6-G3, Lacy Spring 2017 crwdns2935289:0USF Tampa, Team S6-G3, Lacy Spring 2017crwdne2935289:0
USFT-LACY-S17S6G3
That would be the guide to take off the upper DISPLAY ASSEMBLY, not the screen.
I was expecting you to bring iOpeners and get the actual glass LCD out …
But it’s a good guide.
Xavier Jiang - crwdns2934203:0crwdne2934203:0
Is there a way only the screen can be replaced on Dell XPS 13, not the entire display assembly. From what I have got so far, the entire panel above the keyboard is a single unit
Abhi B - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,505
