Dell XPS 13 9370 Battery Replacement
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 13 9370 Battery Replacement, Remove the base cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly.
    Use a magnifying glass to help see the screw heads. Pick the tool driver to match. Be in a clean environment with white paper to set the screws on and a bright overhead light. Go slow.
    M A - crwdns2934203:0crwdne2934203:0
  2. Dell XPS 13 9370 Battery Replacement, Remove the base cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 9370 Battery Replacement, Remove the base cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe (spudger), pry the base cover from the palm-rest assembly.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  3. Dell XPS 13 9370 Battery Replacement, Disconnect battery cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery cable from the system board.
  4. Dell XPS 13 9370 Battery Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
    Perfect guide! Many thanks.
    I didn’t have a spudger bu my wife’s tweezers were an excellent substitute - and also invaluable for dealing with tiny screws.
    Daman Singh - crwdns2934203:0crwdne2934203:0
    The M1.6x4 screw fit a phillips #0 much better than a #00 for me.
    Andrew - crwdns2934203:0crwdne2934203:0
To replace the battery & reassemble your device, follow these instructions in reverse order.
crwdns2935229:026crwdne2935229:0
Max Kletskov
crwdns2935283:004/22/20crwdne2935283:0
41 087 crwdns2915208:0crwdne2915208:0
The Home Depot crwdns2935289:0The Home Depotcrwdne2935289:0
Community
crwdns2931471:019 279crwdne2931471:0
crwdns2935297:0111crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Is the battery an original dell battery?
mnyousafva - crwdns2934203:0crwdne2934203:0
Why doesn’t it say what tools are needed?
Noah Guirguis - crwdns2934203:0crwdne2934203:0
Excellent guide. Took me about 25 minutes. Works perfectly.
Jeff Doremus - crwdns2934203:0crwdne2934203:0
Instructions were perfect, thanks for the great guide!
surfdaworld - crwdns2934203:0crwdne2934203:0
Boom, in a good way! I fixed it!
Chris Cox - crwdns2934203:0crwdne2934203:0
Instructions were perfect, thank you.
Oliver J. Morais - crwdns2934203:0crwdne2934203:0
Instructions were helpful, the battery was replaced after 20 minutes. But then I needed more than an hour to recover from the loss of BIOS information. I have a dual boot Linux/Windows laptop and after the battery replacement the disk mode was set to "raid" but my previous settings were "AHCI". After having fixed that the laptop insisted to boot into Windows. I had to add another entry in the boot menu with the correct boot loader that engaged the grub boot loader. The new battery from DELL lets me survive again more than one day with the laptop.
Wolfgang Friebel - crwdns2934203:0crwdne2934203:0
Replaced my dell battery with the one from Ifixit, wen’t perfectly for a month or so and today the computer just won’t charge the battery. I am pretty desperate about this, any one have advices ?
Max Jgr - crwdns2934203:0crwdne2934203:0
Small screwdrivers needed are listed in parentheses. Great instructions. Only thing I'd add is be careful pulling the cover off at the back edge. Very delicate tabs broke off my machine because I pulled up at the back... should have spludged more carefully.
Allison Cherry Ostriker - crwdns2934203:0crwdne2934203:0
Worked great. Just go slow and precise. Use the iFixit tools or something equivalent. 20-30 minutes for a first time fixer.
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 247
crwdns2942667:0crwdne2942667:0 20,703
