Dell XPS 13 7390 Battery Replacement
  1. Dell XPS 13 7390 Battery Replacement, Removing the base cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 13 7390 Battery Replacement, Removing the base cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 13 7390 Battery Replacement, Removing the base cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe, pry the base cover from the palm-rest assembly, starting at the front left and right corners.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
    My xps 7390 attempts to power on after removing the screws, and partially opening the lid at an angle to pry it open. I stopped following the instructions at this point for fear of a problem. I sought some advice from the web and learned that some XPS 7390's have a power on option when the lid is open, which you simply turn off. Mine does not appear to have that option.
    Uncle - crwdns2934203:0crwdne2934203:0
    UPDATE - I found the Lid Power Option through the F2 Bios function. It was all the way at the bottom and I missed it. My apologies.
  2. Dell XPS 13 7390 Battery Replacement, Remove the old battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 7390 Battery Replacement, Remove the old battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ensure that the battery cable is disconnected from the system board.
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
    I'm a newbie at this, but it would really help if the particular screw driver bit I needed was highlighted in it's position in an image of the pro tool kit.
    Tara Ram - crwdns2934203:0crwdne2934203:0
  3. Dell XPS 13 7390 Battery Replacement, Insert the new battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the screw holes on the battery with the screw holes on the palm-rest assembly.
    • Replace the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Replace the screw (M1.6x4) that secures the battery to the palm-rest assembly
    Somewhere here, presumably after replacing the screws, the battery connector has to be connected to the motherboard. The original Dell manual is also missing this step.
    Michael Haggerty - crwdns2934203:0crwdne2934203:0
    Missing instruction in Step 3: there should be a reminder to the Installer to PLUG IN the battery connector to the system board!
    Rick Butler - crwdns2934203:0crwdne2934203:0
  4. Dell XPS 13 7390 Battery Replacement, Reattach base case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 7390 Battery Replacement, Reattach base case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the screw holes on the base cover with the screw holes on the palm-rest assembly and slide in the base cover into place.
    • Replace the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly
Congratulations, you’re all done!
crwdns2935229:016crwdne2935229:0
Max Kletskov
crwdns2935283:004/22/20crwdne2935283:0
41.087 crwdns2915208:0crwdne2915208:0
The Home Depot crwdns2935289:0The Home Depotcrwdne2935289:0
Community
crwdns2931471:019.254crwdne2931471:0
crwdns2935297:0111crwdne2935297:0
I have an xps 13 7390 and when I perform step 1 - prying open the base cover - the computer turns on. I searched the internet for how to configure my PC to not automatically power on when the lid opens (even when it's only opened 1/4 of the way it tries to turn on) and my BIOS does not seem to have a Power On - Lid Open on/off option. Any suggestions? Thanks.
UPDATE - My XPS 7390 does, in fact, have a LID Power on/off option through the F2 Function. This gets you into BIOS and it was all the way at the bottom of the Power Management option. Apologies.
This guide is better and more accurate than Dell’s website. Just replaced the battery DHGH8 (4-cell 52 Wh, 7.6 V) in my XPS 7390 with no problems.
Jacob Wickham - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 24
crwdns2936753:07crwdne2936753:0 104
crwdns2936753:030crwdne2936753:0 462
crwdns2942667:0crwdne2942667:0 19,712
