Dell XPS 12 9Q23 Touch Pad Replacement
  1. Dell XPS 12 9Q23 Touch Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Touch Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Touch Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Touch Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Touch Pad Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all the screws have been removed the battery is now safe to extract
  6. Dell XPS 12 9Q23 Touch Pad Replacement, Touch Pad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the touchpad cable.
  7. Dell XPS 12 9Q23 Touch Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert wisdom here.
  8. Dell XPS 12 9Q23 Touch Pad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 4 touchpad screws.
  9. Dell XPS 12 9Q23 Touch Pad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the touchpad.
You should now have successfully changed the touchpad on your Dell XPS 12 9Q23 after following the instructions in this article. You've fixed your laptop by gently taking off the back panel, unplugging the battery, and replacing the broken touchpad. Make sure to firmly reassemble every part, by following the instructions in reverse order, then double-check your work to make sure nothing is missing. Once your replacement touchpad is placed, your device should be operating at peak efficiency and you can use it without any problems going forward.
DJ Jackson
crwdns2935283:004/11/17crwdne2935283:0
384 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S1-G2, Kim Spring 2017 crwdns2935289:0University of Memphis, Team S1-G2, Kim Spring 2017crwdne2935289:0
UM-KIM-S17S1G2
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,775
