Dell XPS 12 9Q23 Battery Replacement
  1. Dell XPS 12 9Q23 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove back panel after all screws have been removed.
    I suggest sliding an opening tool along the front of the case first to pop the plastic snaps holding the cover to the bottom of the laptop. The snaps near the hinges are the most challenging. It is also important, when following these directions in reverse order, to fit the right side of the case over the sliding power switch before applying downward pressure required to snap the case bottom back into place. Wouldn’t want to break your power switch.
    Jeremy Tilden - crwdns2934203:0crwdne2934203:0
  3. Dell XPS 12 9Q23 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Battery Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all the screws have been removed the battery is now safe to extract
crwdns2935229:05crwdne2935229:0
Kyle Yatsula
crwdns2935283:004/04/17crwdne2935283:0
162 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S1-G2, Kim Spring 2017 crwdns2935289:0University of Memphis, Team S1-G2, Kim Spring 2017crwdne2935289:0
UM-KIM-S17S1G2
Any tips for registering the new battery in the BIOS?
Ryan Porter - crwdns2934203:0crwdne2934203:0
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
https://fr.ifixit.com/R%C3%A9ponses/Devi...
Schwarzer -
crwdns2942667:0crwdne2942667:0 4,561
