As one of the key features of a laptop, the mouse pad is one of the elements of the device that is most likely to suffer wear over time. The right/left click buttons are especially susceptible to wear and tear, as these are mechanical systems connected to electrical boards.
If your left-click or right-click buttons aren't working, you may need to replace the board that controls those functions. Use this guide to learn how!
Flip the device over. Unscrew nine marked 7mm Phillips #1 screws.
Remove the keyboard by pushing back the tabs at the marked locations with a spudger or plastic opening tool.
Turn the device around so the screen is closest to you. Lift the keyboard and detach the ribbon cable with the spudger.
Remove the keyboard and set it aside. Detach the other ribbon cables with the spudger.
Remove five 8mm Phillips #1 screws.
Pry open the laptop with the plastic opening tool.
Under the trackpad, detach the ribbon cables with the spudger.
Unscrew two 3mm Phillips #1 screws and lift the board from the pegs.
Remove the board from the laptop.
