Depending on the configuration of the laptop you own there may be one or two memory sticks located inside the compartment.
With the computer facing down locate the RAM compartment cover.
Unscrew the two screws holding the cover to the laptop chassis.
Lift up on the Memory cover and remove.
Using a plastic opening tool push outward on both sides of the RAM stick.
