In this guide, we will be showing you how to remove and replace the Hard Drive.
Slide the release latches to unlock the battery.
Slide the battery out of the chassis and remove it from the computer.
Loosen the screws that secure the memory door.
Pry up the memory door near the screw hole, lift, and remove it
Remove the screws that secure the hard-drive bracket.
Slide the hard drive module in the direction shown in the image below.
Remove the hard drive module from the system board.
Slide the hard drive from the hard-drive bracket.
thanks for that info ! ! ! :-)
