In this guide, we will show you how to remove and replace the Memory Module.
Flip the computer over.
Slide the battery release latch to the unlock position.
Slide the other battery release latch to the unlock position.
Slide the battery and remove it from the computer.
Remove the screws that secure the base cover to the computer.
Lift up the base cover and remove it from the computer.
Push apart the memory retention clips to release the memory module.
Remove the memory module from its connector on the system board.
