Slide the release latches to unlock the battery.
Slide the battery and remove it from the computer.
Remove the screws that secure the access panel to the base of the computer.
Lift the access panel up at an angle and remove it from the computer.
Pry the retention clips away from the memory module until it pops up.
Remove the memory module from its connector on the system board.
